3GPP TSG RAN Meeting #108 RP-251860 Prague, Czech Republic, June 9-13,2025 (revisionof RP-yyxxxx)
Source: Qualcomm Title: NewWI: Artificial Intelligence (AI)/Machine Learning (ML) for NR air interfaceenhancements Documentfor: Approval AgendaItem: 15.1.1
3GPP™ WorkItem Description Information on Work Items canbe found at http://www.3gpp.org/Work-Items
See also the 3GPPWorking Procedures, article 39 and the TSG Working Methods in 3GPP TR 21.900 Title: NewWI: Artificial Intelligence (AI)/Machine Learning (ML) for NR air interfaceenhancements
Acronym: NR_AIML_air_Ph2
Unique identifier: XXX
NOTE: For new WIs/SIs leave the Uniqueidentifier empty and make a proposal for an Acronym. For a revised WI/SI: Take Uniqueidentifier and acronym as shown in 3GPP workplan. If this is a RAN WIDincluding Core and Perf. part, then Title, Acronym and Unique identifierrefer to the feature WI. Please tick (X) theapplicable box(es) in the table below: Either: This WID includes a Core part | X | This WID includes a Performance part | X |
or: This WID includes a Testing part |
| and it addresses the following 3GPP work area: | Radio Access |
| Core Network |
| Services |
Potential targetRelease: Rel-20
NOTE: In case ofcontradiction with the target dates of clause 5, clause 5 determines the targetrelease. 1 Impacts
Affects: | UICC apps | ME | AN | CN | Others (specify) | Yes |
| X | X |
| No | X |
| X |
| Don't know |
2 Classificationof the Work Item and linked work items
2.1 PrimaryclassificationThis description is either a… or a Normative Work Item: tick applicable boxes below |
| Stage 1 | X | Stage 2 | X | Stage 3 |
| Other (e.g. testing) |
2.2 ParentWork ItemFor a brand-new topic, use “N/A” in thetable below. Otherwise indicate the parent Work Item. Parent Work / Study Items | Acronym | Working Group | Unique ID | Title (as in 3GPP Work Plan) | FS_NR_AIML_air | RAN1 | 940084 | Study on Artificial Intelligence (AI)/Machine Learning (ML) for NR Air Interface | FS_NR_AIML_air_Ph2 | RAN1 | 1060078 | Study on Artificial Intelligence (AI)/Machine Learning (ML) for NR air interface Phase 2 |
NOTE: RAN agreedsome time ago, that it describes the feature WI + Core/Perf. part WI or Testingpart WI in one WID. Therefore the tableabove should include the feature WI data (In case the feature covers Core andPerf. part, please list under WorkingGroup the leading WG of the Core part). 2.3 Otherrelated Work Items and dependencies
Other related Work/Study Items (if any) | Acronym | Unique ID | Title | Nature of relationship | NR_AIML_air | 1020093 | Artificial Intelligence (AI)/Machine Learning (ML) for NR Air Interface | Preceding work item. |
NOTE: Also related or dependent WIs/SIs in otherTSGs shall be indicated here.
Dependencyon non-3GPP (draft) specification: None. 3 Justification
Theapplication of AI/ML techniques to NR air interface has been studied inFS_NR_AIML_air and FS_NR_AIML_air_Ph2. Normative support for the generalframework for AI/ML for air interface and some of the use cases studied in FS_NR_AIML_airwas provided through the NR_AIML_air related project. In thiswork item, we provide the normative support for the CSI feedback enhancement (two-sidedmodel) use case as well as standards-based UE data collection. 4 Objective
4.1 Objectiveof SI or Core part WI or Testing part WIProvide specification support for thefollowing aspects:
AI/ML frameworkfor two sided AI/ML models within the realm of what has been studied in theFS_NR_AIML_air_Ph2 and NR_AIML_air projects for CSI feedback enhancement[RAN2]: - Signalling and protocol aspects of Life CycleManagement (LCM) enabling functionality and model selection, activation,deactivation, switching, fallback o ID relatedsignalling is part of the above objective - Necessary signalling/mechanism(s) for LCM tofacilitate model training, inference, performance monitoring,.
CSIfeedback enhancement, encompassing (two-sided model) [RAN1, RAN2]: - CSI spatial/frequency compression without temporalaspects (“Case 0”), - Specify necessary signalling/mechanism(s) as per theidentified potential specification impacts in FS_NR_AIML_Air , including: o Modelpairing procedure including ID and applicability reporting o Inferenceaspects including target CSI type, measurement and report configuration, CQI RIdetermination, payload determination, quantization configuration codebook, UCImapping, CSI processing criteria and timeline, priority rules for CSI reports o NW and UEside data collection for training, § Target CSIformat § Note Theframework defined in BM and CSI prediction use cases could be reused o Specifyperformance monitoring
Inter-vendortraining collaboration for two-sided AI/ML models - Fully defined/specified reference model (“DirectionC”) with RAN1 scalability study outcome taken into account [RAN4/RAN1] – check-point in RAN#110 upon RAN4feedback o Specification of standardized encoder modelstructure plus parameter exchange (“Direction A, sub-option 3a-1” withouttarget CSI sharing) leveraging defined/reference model of “Direction C” andtaking RAN1 scalability study outcome into account [RAN4/RAN1/RAN2/RAN3] – check-point in RAN#110 upon SA WGfeedback - Specification of standardized dataset format/contentplus dataset exchange (“Direction A, sub-option 4-1”) [RAN1/RAN2/RAN3/RAN4] – check-point in RAN#110 upon SA WGfeedback
Datacollection [RAN2]: - Further study and specify if deemed necessary,standards-based UE data collection at least for UE-side model training in closecollaboration with SA WGs and taking into account the agreed principles duringthe Rel-19 study –check-point in RAN#110 based on SA WG feedback and SA2 study on data collection
Interoperabilityand RRM requirement [RAN4]: - To define the requirement for the encoder, specifythe standardized test decoder to guarantee interoperability o The fullyspecified test decoder, data set, and corresponding reference encoder in RAN4to be used for inter-vendor collaboration - Necessary RRM requirement for specified LCMprocedures. - NOTE: offline training is assumed for the purpose ofthis project. Strive to leverage on RAN1’s study on scalable model structure inFS_NR_AIML_Air.
4.2 Objectiveof Performance part WINOTE: Leave empty if the WI proposal does not contain a RANperformance part. Performancerequirements [RAN 4]: - Demodulation requirement for CSI compression Case 0 - RRM performance test cases for the corresponding RRMrequirement for LCM procedures.
4.3 RANtime budget request (not applicable to RAN5 WIs/SIs)NOTE: For all new RAN related WIs/SIs which are not led byRAN WG5 the WI/SI rapporteur has to fill out the attached Excel table torequest time budgets for corresponding RAN WG meetings.
The Excel table has to be filled out for all affected RAN WGs and up to thetarget date of the WI/SI.
One time unit (TU) corresponds to ~ 2 hours in the meeting.
If no TU is needed, then leave the field empty otherwise enter a number >0in the field. For revisions of already approved WI/SIdescriptions: Please remove the Excel table from the WID/SID's zip file.The time budgets are already recorded. If you want to modify them, then thishas to be done via the status report and not via a revised WID/SID. If this WID is covering Core and Performance part,then please fill out one line for each part in the attached Excel table. additional comments to the time budget request in theattached Excel table:
5 ExpectedOutput and Time scale
New specifications {One line per specification. Create/delete lines as needed} | Type | TS/TR number | Title | For info
at TSG# | For approval at TSG# | Remarks |
NOTE: If this is a RAN WI including Core andPerf. part, then all new Core part specs have to be listed first and then allnew Perf. part specs. Indicate "Core part" or "Perf. part"under Remarks for each spec.
By default a new specs can only be new for one of both parts.
Impacted existing TS/TR {One line per specification. Create/delete lines as needed} | TS/TR No. | Description of change | Target completion plenary# | Remarks | 38.300 | Feature introduction. | TSG#115 | Core part | 38.214 | Feature introduction. | TSG#115 | Core part | 38.331 | Feature introduction. | TSG#115 | Core part | 38.133 | Feature introduction. | TSG#115 | Core part | 38.401 | Feature introduction. | TSG#115 | Core part | 38.133 | Feature introduction. | TSG#117 | Perf. Part |
If an existing spec is affected by both (Core part and Perf. part), then it hasto be listed twice with appropriate approval dates.
6 Workitem Rapporteur(s)
NOTE: The first listed Rapporteur has theoverall responsibility for this WI (incl all secondary tasks). 7 Workitem leadership
Primary: RAN1 Secondary: RAN2, RAN3, RAN4
8 Aspectsthat involve other WGs
For a Stage 2 WID requiring Stage 3 to be done by another group: on abest-effort basis, indicate which potential WG is expected to specify the Stage3: possible values: "Not applicable" NOTE: For RAN WIs: Section 8 applies only to WGs outside ofTSG RAN because all RAN WG aspects have to be covered in section 4.
9 SupportingIndividual Members
Supporting IM name |
Qualcomm
CAICT
Ericsson
Nokia
CATT
CEWiT
China Telecom
China Unicom
ETRI
FirstNet
Futurewei
III
IITM
Intel
InterDigital
ITRI
Kyocera Corporation
LG Electronics
MediaTek
NEC
Nvidia
Ofinno
Panasonic
Samsung
Sanechips
SK Telecom
Spreadtrum
Telefonica
UNISOC
vivo
ZTE
