发表于 2025-6-20 11:52:39 |显示全部楼层
As Wi-Fi 7 technology continues to evolve, selecting the right platform becomes a key decision for device manufacturers and solution integrators. Among Qualcomm’s flagship Wi-Fi 7 SoCs, the IPQ9574 and IPQ9570 stand out with similar architectures but serve slightly different application needs. This article provides a detailed overview of both chips to help guide optimal product planning and development.
✅ 1. Positioning and Target ApplicationsChip ModelPositioningTypical Use Cases
IPQ9574Enterprise / Carrier GradeTri-band routers, Wi-Fi mesh, 5G CPE, wireless backhaul
IPQ9570Commercial / Mid-High EndDual-band home routers, enterprise APs, IoT gateways
  • IPQ9574 supports full tri-band (2.4G / 5G / 6G) operations, ideal for high-performance wireless networking such as mesh or CPEs with backhaul.
  • IPQ9570 focuses on dual-band support, offering cost-effective Wi-Fi 7 solutions for commercial and consumer markets.
⚙️ 2. Key Specification OverviewFeatureIPQ9574IPQ9570
CPUQuad-core ARM Cortex-A73 @ 2.2GHzQuad-core ARM Cortex-A73 @ 2.2GHz
Process Technology14nm FinFET14nm FinFET
Wireless Bands2.4GHz / 5GHz / 6GHz (tri-band)2.4GHz / 5GHz (6G optional)
MIMO SupportUp to 4x4 MIMO per band2x2 or 4x4 depending on design
Ethernet SupportUp to 10GbE + multiple GbE ports1GbE / 2.5GbE
Storage InterfacesNAND, NOR, eMMCNAND, NOR, eMMC
Wi-Fi StandardIEEE 802.11be (Wi-Fi 7)IEEE 802.11be (Wi-Fi 7)
Acceleration EnginesHW NAT, Crypto, QoS, IPSecHW NAT, Crypto, QoS, IPSec
Software SupportOpenWRT / Qualcomm SDKOpenWRT / Qualcomm SDK
📌 3. Shared Advantages
  • Wi-Fi 7 Support:
    Both platforms support 802.11be, including:
    • 320MHz channel width
    • Multi-Link Operation (MLO)
    • 4096-QAM modulation
  • High-performance ARM Architecture:
    The quad-core Cortex-A73 offers enough processing power for advanced networking, VPN, mesh coordination, or edge computing.
  • Developer-Friendly Platforms:
    Fully compatible with OpenWRT, enabling rapid software development, UI customization, remote management, and OTA updates.
🧠 4. Recommended Application ScenariosApplication ScenarioRecommended ChipReason
Tri-band mesh routersIPQ9574Full tri-band + high computing power for AP coordination
Wireless backhaul APsIPQ95746GHz for backhaul, 5G for access – optimal isolation
Industrial IoT gatewaysIPQ9570Lower cost, sufficient performance, stable connectivity
Home Wi-Fi 7 routersIPQ9570Affordable dual-band Wi-Fi 7 solution
Carrier-grade CPE/ONUIPQ9574Supports high-throughput scenarios with 10G support
🔩 5. Position Within Qualcomm’s SoC PortfolioChipsetWi-Fi VersionMarket TierNotes
IPQ5018Wi-Fi 6Entry-LevelFor lightweight gateways and IoT
IPQ6018Wi-Fi 6Mid-TierCommon in dual-band routers/APs
IPQ9570Wi-Fi 7Mid-to-High Dual-BandBalanced cost and performance
IPQ9574Wi-Fi 7Flagship Tri-BandIdeal for enterprise mesh, 10GbE CPEs
✅ ConclusionIf your project requires Wi-Fi 7 tri-band performance, wireless backhaul, or enterprise-level throughput, the IPQ9574 is your go-to solution.
For dual-band applications focused on cost-efficiency and deployment flexibility—while still benefiting from Wi-Fi 7 core advantages—IPQ9570 is the right choice.
Both chipsets integrate seamlessly with Qualcomm’s QCN series (e.g., QCN9274, QCN6274, QCN9024), forming a complete and scalable Wi-Fi 7 platform. ODMs like WallysTech have released commercial modules and boards based on these platforms, allowing faster time-to-market for Wi-Fi 7 products.
GMT+8, 2025-6-23 19:14 , Processed in 0.144300 second(s), 16 queries , Gzip On.
